Josh775 Posted June 13, 2014 Share Posted June 13, 2014 Hi all my mk1 focus has made a strange noise since i bought it (1 week ago) it's done 123k miles with no history.. Happens with turning on and off. The garage thought it was the alternator tensioner and belt so replaced all that FOC. Still an issue they think its the waterpump. Has anyone come across this before?? Its 1.8 tdci 54 plate. I've done all the filters and I'm doing Oil/Glow plugs/Cambelt/Waterpump next week anyway but wanted to check if the Waterpump could cause this? Many thanks josh. - Vid below. Quote Link to comment Share on other sites More sharing options...
Rick984 Posted June 13, 2014 Share Posted June 13, 2014 Engine mounts? Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 13, 2014 Author Share Posted June 13, 2014 Engine mounts? I didn't think of that. Would it not be making a horrible racket when running if that were the case though? Or is it because it moves/vibrates so much on turning on/off that it's doing it? Thanks. Quote Link to comment Share on other sites More sharing options...
Rick984 Posted June 13, 2014 Share Posted June 13, 2014 Yeah obviously the engine vibrates quite a bit when turning on and off, thats what made me think of that, could be the exhaust rubbing against something too Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 14, 2014 Author Share Posted June 14, 2014 Can anyone think of anything else that it could be also? (Vid is in the op) :) Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 18, 2014 Author Share Posted June 18, 2014 Just to update, cars had full Major service........ Cambelt/Waterpump/Coolant/Oil/Filter/Fuel Filter.... Still makin this noise. Argh it's driving me mad, lol. Quote Link to comment Share on other sites More sharing options...
theduke Posted June 18, 2014 Share Posted June 18, 2014 Did they change the auxilary belt aswell, Could be the aux belt tensioner causing aux belt to squeak? Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 18, 2014 Share Posted June 18, 2014 Does your car have ac? Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 18, 2014 Share Posted June 18, 2014 Engine mounts ? Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 18, 2014 Author Share Posted June 18, 2014 Hi, thanks for replies, Yeah the car has Air Con and they put a brand new belt and aux tensioner on. Aswell as Cambelt/Waterpump. Thanks. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 19, 2014 Share Posted June 19, 2014 You could have a issue with the ac. Might be seized or the pulley. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 19, 2014 Share Posted June 19, 2014 Has the sound changed at all? ie louder once the belts etc was changed? Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 19, 2014 Author Share Posted June 19, 2014 I would say the sound has got louder/harsher definetely yes. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 19, 2014 Share Posted June 19, 2014 Yh sound like ur ad is seized or something is. Have the belt taken off and see if everything that are attach to the belt move freely. Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 19, 2014 Author Share Posted June 19, 2014 Yh sound like ur ad is seized or something is. Have the belt taken off and see if everything that are attach to the belt move freely. Ok,. I'll take a look this weekend and try figure it out :). Thanks! Quote Link to comment Share on other sites More sharing options...
Josh775 Posted June 23, 2014 Author Share Posted June 23, 2014 Air con pulleys not siezed all runs freely. Had all the engine cover off and got underneath and the noise is coming from the Starter Motor/Alternator. Could this be the case? I also found alot of oil underneath gearbox/engine - Could this be from Garage oil change last week? (I Hope so!). Cleaned all that up and I'm going to keep an eye on it. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 23, 2014 Share Posted June 23, 2014 Check oil level. As for the sound. If it's coming from the starter/alternator check that they are all good. Make sure to check idler and everything else in that region. Quote Link to comment Share on other sites More sharing options...
Josh775 Posted July 2, 2014 Author Share Posted July 2, 2014 Checked oil Level seemed fine.. Got under to show you all to hear the noise more clearly. Quote Link to comment Share on other sites More sharing options...
Josh775 Posted July 29, 2014 Author Share Posted July 29, 2014 Hi all, just to update. The noise is still present but my battery started to die. Anyway, new battery has made the noise a significant amount quieter. Which makes me think this is definetely the Starter.. Although it still makes the noise when turning off also. Will update you further when I try further things :) Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted July 29, 2014 Share Posted July 29, 2014 Could also be the alternator not charging the battery. That would be the first thing I would change. Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Josh775 Posted October 5, 2014 Author Share Posted October 5, 2014 To update, I replaced the battery which solved the issue. But I was wondering if anyone can shed any more Light on the noise (I am going to check the Starter motor next week when I'm off work but I've been reading it could be the Dual Mass Flywheel and I'm quite concerned....... Thanks Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted October 5, 2014 Share Posted October 5, 2014 DMF's can make a noise on startup/shutdown when they start to fail but usually more of a clatter/shudder than a squeak, that's pretty odd lol. I don't see how it could be the starter motor, it doesn't move at all on shut down. I'd probably be more inclined to say the alternator bearings myself. Quote Link to comment Share on other sites More sharing options...
Marks12 Posted October 5, 2014 Share Posted October 5, 2014 Could also be the alternator not charging the battery. That would be the first thing I would change. Sent from my C5303 using Ford OC mobile app you can check what voltage your alternator is giving out with a multi meter if its off then its the alternator Quote Link to comment Share on other sites More sharing options...
luke.grimbley Posted October 5, 2014 Share Posted October 5, 2014 I'd guess alternator. Check the voltage it's feeding to the battery with a meter. Quote Link to comment Share on other sites More sharing options...
Josh775 Posted October 6, 2014 Author Share Posted October 6, 2014 Thanks for all the replies guys I really appreciate it! I'm going to check the Alternator like you said and I will report back with any findings....I hope that's all it is! much cheaper than a DMF, lol. Gear changes are fine though and the clutch. No vibrations really.s it is a bit of a rattle when it starts though sounds horrible sometimes. Quote Link to comment Share on other sites More sharing options...
