1.6 To 1.8 Engine Swop
STEADS
 Share
Anyone ever done a conversion from a 1.6 to a 1.8 petrol reason for asking is seen a 1.6 one at with a knocking engine going to buy for my son to replace his ageing 1.8 that has a decent engine know it can. Be done just not entirely sure what bits an bobs need to be swopped over ie looms and stuff any pointers great fully received
Link to comment
Im no pro on this but I recon your going to be looking at new mounts, looms, fuel lines I expect will need to get swapped also.
Plus you should also check the gearbox and clutch as they may need to get swapped to!
Link to comment
Engine, gearbox, egine loom, mounts, everythin on engine (pas pump etc) may need water pipes an radiator. Might be diffrent
Sent from my GT-I9195 using Ford OC mobile app
Link to comment
Fingers crossed then, its just a case of starting from scratch but you should be able to do it, as long as you dont forget the ECU and keep the best GEM then you should get the best of both worlds.
Link to comment
Agree with you james had a look before had a pic of a 1.6 eng and then looked at my lads to much to swop over do able but a pain .
Link to comment
Jamie don't mention 2.0ltrs to me lol just had a gut full of the one I've tried to get running correctly on and off over the last two years so slammed it on eBay as a non runner been to good to scrap but this had totally defeated me .
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
