briantopp Posted June 14, 2014 Share Posted June 14, 2014 Hi, my current wipers are leaving smears across the windscreen so I purchased some Bosch Aerotwin A310S blades as they appeared to fit my 2010 C-Max. I've gone to replace them and run into a problem so wondered if anyone could help. The car has a sidelock fitting and the Bosch website states that the A310S blades come pre-assembled with a "multi-clip adaptor" that is compatible with this fitting, the problem is that I can't work out how to get them to fit. Has anybody got any experience of these blades (or the Aerotwin range) who can offer an idiots guide on how to fit them please? I've attached two pictures as well, one shows the adaptor as it comes out of the box and the second is with the casing removed (if that makes sense). Many thanks in advance. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 14, 2014 Share Posted June 14, 2014 Its just the pin holding it in place isnt it? Quote Link to comment Share on other sites More sharing options...
briantopp Posted June 14, 2014 Author Share Posted June 14, 2014 The bit of plastic that I've removed in the second picture is only held in place by the metal pin shown if that's what you mean. Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 14, 2014 Share Posted June 14, 2014 normally I just carry the old cover to the new blade. If I am thinking right, you have the pole type blades, where you just put it in at a 90 degree angle and push it onto the pin on the wiper arm, then it locks in after you flatten it. If your struggling to get the new cover on just recycle the old ) Quote Link to comment Share on other sites More sharing options...
