Washers
Got a 58 plate ford focus the sprayers are not working front or back can't here the motor going when press the button but both wipers work I ve checked the fuses I've also took pump off and that works fine I have now change the column switch and still not working anyone got any ideas would be appreciated
Check the fuse too
Any idea which relay needs changing looked through Manuel don't say which one to change
I may have wrong footed you.
The wipers use a relay but the wash motor is fuse controlled.
Check the fuse and change it even if it looks ok, a blown one can be hard to diagnose sometimes.
It has a fuse and relay clive so you are correct. Look on the inside of your engine fuse box cover for relay layouts. Washer relays will have the same symbol as it does on your wiper stalk
