badvok Posted June 21, 2014 Share Posted June 21, 2014 Hi, I've notice a small leak near a hose, photo below. Do you think it is coming from the hose? Is it easy to replace? What can I do about the mess accumilating on the wiring? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted June 21, 2014 Share Posted June 21, 2014 definately looks like it. I would suggest pulling that pipe off, and see if you can do anything with it, perhaps add a sealant to the pipe before putting the hose on. Also might be worth checking that the jubilee clip is tightened. As for the wires, start off with wet wipes (daft as it sounds) and wipe the crud off the wires, and see if you can clean them up that way. Quote Link to comment Share on other sites More sharing options...
