algenash12 Posted June 29, 2014 Share Posted June 29, 2014 Hi am having a couple of issues with cental locking 1) car locks and unlocks itself while driving. 2). When locking the car no longer get indicators flashing (double tap key fob) Any help appreciated Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 30, 2014 Share Posted June 30, 2014 Check key battery. Change it if you can. Then see if it sorts it. If not might be a faulty key or module. Quote Link to comment Share on other sites More sharing options...
mjt Posted June 30, 2014 Share Posted June 30, 2014 Some cars have the option to lock the doors above a certain speed, e.g. 5mph. I don't know if this is an option on your model but if they lock as you drive off then unlock when you stop that might be the explanation. Quote Link to comment Share on other sites More sharing options...
algenash12 Posted June 30, 2014 Author Share Posted June 30, 2014 Have now noticed that car locks and unlocks itself when parked up, and no one sat in it. Any ideas?? Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted June 30, 2014 Share Posted June 30, 2014 It may be the key. Take battery out then try. Quote Link to comment Share on other sites More sharing options...
algenash12 Posted July 1, 2014 Author Share Posted July 1, 2014 Took battery out, still was doing the same, someone at work has same focus model as me and said it could be fuse 63. But he couldn't remember where you find it. Is it worth me checking that fuse? And where would I find it? Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted July 1, 2014 Share Posted July 1, 2014 Worth checking. It's passenger footwell fuse box. Quote Link to comment Share on other sites More sharing options...
algenash12 Posted July 3, 2014 Author Share Posted July 3, 2014 Have checked all fuses and keyfob battery, still having same problem. Central locking seems to play up the most first thing in the morning when driving to work, will constantly lock and unlock while driving. When at work park up and lock the car (no indicator flash) check all doors and boot they seem locked Then go inside, pop outside 5 mins later car is unlocked. But come lunchtime central locking working fine, get indicator flash when lock the car. Car stays locked, and There no locking or unlocking while driving. Problems return again in the evening. Quote Link to comment Share on other sites More sharing options...
nazsky786 Posted July 5, 2014 Share Posted July 5, 2014 Have you tried it without a battery being in the keyfob for a while. Lock the car using the key. That way you find out if its the key or the module. Quote Link to comment Share on other sites More sharing options...
