Suspension/low
Hello , anyone knows how low
does our zetec s sits normally ?
and "how much" sport is our suspension?
zetec s are 10mm lower than standard if my memory is correct i cannot tell you the acc height tho
only 10mm? im about to
lower it but i want to get sure that it aint 35mm for sure before buying a kit
I'm sure the Zetec S' are lowered by 15mm from standard, basically if you were going to go for a 35mm kit expect a 20mm drop and so on with other sizes of drops.
It's definitely not 35mm already. I've got 30mm eibach springs on mine and there's a noticable difference (lower :)) to standard.
Scott
With 35mm I have like 20 mm or so of clearance between the tyre and arch, you'd notice it!
Sent from my SM-G900F using Ford OC mobile app
Just don't carry fat chicks in there, most cars will go 50MM before they encounter issues like rubbing and bump stops, keeping your load under a size 8 will save you a world of issues.
thanks for the replies guys .
hahaha true matt , naaa i just think i go for the redline suspension eibach.. just not sure for the stiffness..
Haha I have 35mm Eibach and they're honestly not bad!
You'll be fine, just be careful in multistorey car parks!
its just our "sport suspension" that i dont know how perfect matches the eibach redline kit
