O3 Fiesta Ghia 1.6 Engine Judding
hi every one. I needs help please if someone can some times when I pull away it fill like the engine want to rip it self out of the engine bay it don't feel like clutch judder but got to release the clutch slowly and play with the rev to get it to go smooth not all times it works when cold do not happen and in between gear change the rev's stay were they are for a second or 2 longer then the gear change then the bite of the clutch seem a bit snappy the things I have done change all engine mounts the old ones was bad the problem has rip them apart. full service plugs air oil belt throttle body taken off cleaned connecters cleaned. any help would be nice as it starting to bake the head thinking about it what it can be that doing it. if any body else has had this please help.
thank you anyone
barry
Hi Barry,
Check for engine and gearbox mount condition. This is the first place I would start. Also it could be a sign that the clutch is running out of puff!
