ScottyMc Posted July 16, 2014 Share Posted July 16, 2014 (edited) Morning folks, I've had my 13 plate Mondeo for over two months now and within the last month I've noticed a squeak which sounds as though it's coming from the NSF. It only happens when I go over a small pothole or into the edge of a drain (where the tarmac starts to roll down towards the drain itself). You can only hear it when the windows are open but you can imagine in this weather, I'm driving around a lot like this and the nose is both irritating and embarrassing. I've had the car back to the dealers who first stripped down the NSF strut, reseated and greased everything which didn't cure it. I then had it back last week where they replaced the shockers but still, I'm left with an annoying squeak. Thoughts on what it could be? Edited July 16, 2014 by ScottyMc Quote Link to comment Share on other sites More sharing options...
Italiot Posted July 16, 2014 Share Posted July 16, 2014 I've had that problem on peugeot 308 but never fords on the peugeots the problem is this heat sheild needs tightening would get that checked or doesn't take long Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 16, 2014 Share Posted July 16, 2014 I have the same sorta thing, moreso a rattle with a little squeak on mine, but either way it happens over potholes or bumpy roads, I suspect it to be the top mount. I would take it ford as its under warranty and let them deal with it :) Quote Link to comment Share on other sites More sharing options...
Italiot Posted July 16, 2014 Share Posted July 16, 2014 No it's out of warranty and can't afford their aftermarket prices Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Italiot Posted July 16, 2014 Share Posted July 16, 2014 I will probably give it another go on the weekend Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
karlos1987 Posted July 16, 2014 Share Posted July 16, 2014 I'd say top mount aswel. They are cheap aswel. Sent from my C5303 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted July 16, 2014 Share Posted July 16, 2014 sorry, not sure if I overlooked something... if its a 13 plate car, its still in warranty, the car has a 3 years manufacturing warranty - which means any ford dealer can resolve the issue under warranty? 1 Quote Link to comment Share on other sites More sharing options...
