Fiesta Mk6 Water In Spark Plugs And Doesn't Go Past 70 Mph
My fiesta has water in the spark plugs and it's won't do anythink past 70 mph it's like it's holding back very grateful if soneone can help tried new plugs leads and coil pack
Really need help
I know this is a problem I had when I had my old mk6. I changed the coil pack plugs and leads and it fixed the problem it could mean that you need to change them again. I know that this problem is caused by water running down off of the windscreen and down into the engine instead of down the wee gully it's ment to so if you park on a slope try parking other way round
The coil pack was only changed two weeks ago
Hmm Nae great might need done again I think I have read of others having no joy changing it just once have you went back to the garage that did
My dad done it him self I love my fiesta great car
Are the core plugs leaking? Is it pink water around the spark plugs or normal water?
If its normal you might need some seals that fit under the washers jets as they drolip down into the spark plugs and fill it up with water
Sent from my GT-I9195 using Ford OC mobile app
I think it's water cozs it doesn't smell of anythink it's a brown colour
Might req the revised washer jets and seals theb mate. Hopefulky t should stop the water getting into the spark plugs
Head gasket
Sent from my SM-N9005 using Ford OC mobile app
