Ford Fiesta 07 1.4 Diesel 4 Door Something Bent On Front End
Hi I just bought a diesel fiesta diesel on a 57 plate but the car has had a whack to the front wheel or wheels so far I've changed one strut and both rack ends as there where all bent
The problem I'm having is the drivers side front wheel is still not lining up with the back wheel and the camber of the front drivers wheel is more than the other side/leaning in at the top and stepping out at the bottom
I have looked at the front subframe but it looks fine apart from the steering rack has moved about a half inch to the left the bottom wishbones both look fine
So what do you think my problem might be and is there and tests I can do to find the problem
Cheers Leo
Have you changed the wishbone ???
Hi Mike I haven't done anything with the wishbones yet just they look fine no sign of creasing or bending or can they look fine but still be bent?
Ive seen them before were they look ok on a visual inspection, but on changing them, the problem has been resolved. It's a process of elimination really at this stage.
