Foot Well Lights Help!!
Lenny thanks mate
As I said I have ordered the shopping list. I still think red will look good so I will stick with it same as you have.
Also do you have a rocker switch in the obd compartment? The pics make it look like a neat install but would it be a waste just to have a switch for the bird bath lights on their own?
Maybe it would be better just to have them run of the standard dash light switch as your orinally suggested.
Although if I do want to add any later LED mods to the cup holder or door handles would it be possible to link these to the birdbath wiring and then add in the isloater rocker switch to turn all them on and off?
Lenny im greatful for your expertise on this mate.
Thanks again.
no problem at all mate,
I have plenty of time to answer questions on the open forum rather than via a personal message because on the open forum its more documented and many people with same question can see the answers, so its concrete progress for all.
The pictures of the rocker switches are my dash pocket.
The black rocker switch is for my DRL's giving the option to drive in darkness,
The red illuminated switch is for my bird bath illumination and cup holder illumination and being an led equipped switch it also acts as an illuminator for the dash pocket aswell.
You can add a 12v rocker switch to the lighting at a later date and power all of your additional lighting from that switch no problem,
Cracking build thread going on here guys very good in depth info keep it up :p
No problem Lenny.
When all arrives I will keep you posted.
I think I will had the cup holder LEDs as well but I will try the bird bath mod and the footwell's first.
I think the ignition ring maybe take a week or 2 to arrive. So just have to sit about and wait lol!
Great job on your mods Lenny very tidy mate.
No problem Lenny.
Thanks mate,
The rear footwell pads are coming from Housten Texas aswell if there the same supplier as mine,
Defo same part anyways,
If following the cup holder illumination guide id just fit the led to the front of the cup holder its bright enough to illuminate the whole thing,
Its too bright with three strips fitted,
Thanks Lenny.
I will contact you when I'm about to do the cup holder part anyway.
Just want to ask Is the 10 amp cable you linked to be ok for all foot well lights circuit load and will it be ok to link to the dash lights for birdbath and cup holder LED or would the 20 amp version of the cable be better?
also is it useful to add a fuse to the circuit like in press guide?
Thanks again Mate
This might help you sonic.
Watts divided by volts = amps
Thanks Lenny.
Thanks again Mate
10amp is more than sufficent mate 20amp is very heavy cable and unnecessary just for a few led's you could do it all with 5amp but i recommend 10amp just to be sure,
You could fit an inline fuse adaptor if desired but the interior sources your splicing in to already have individual fuses on the board under the glovebox.
No problem Lenny.
thanks again.
Just an update on what I have.
(also have the Front LED Bulbs that are not shown here in pic but can post if you wanna see them)
Hi mate,
sorry for delay in response i was out buying a suit for wedding on 22nd
You can wire in the footwell lighting its on a seperate loom from the bird bath illumination,
You can also run the cable in for the bird bath illumination aswell if desired,
Id start with the illuminated ignition ring, then splice in to that under drives footwell,
splice red to blue and black to black
Run a single feed across the front drivers footwell to the passenger footwell splice a bulb socket to this cable at the drivers footwell and one on the passenger footwell continue this single feed in a backwards 7 formation across from ignition ring to passenger footwell then down the centre console,
Splicing in the bulb sockets where required and attaching the rear pods to the end
Under the centre console,
The single snake feed provides power to everything in one clean sweep saving weight aswell.
Thanks Lenny
I will keep you posted on my progress mate.
Thanks Lenny
no prob,
Ive to go now try out halfords discount card for first time ever in Ireland,
See what they say :)
Also ive to tax car today, but ill keep an hourly check of this thread and my inbox,
Any questions ill get back to you within the hour mate,
I did this mod on my car before i found the forum, nice and easy to do and the guide is great. i first did this on my Golf Mk4 a good few years back after seeing it in a new (or what was new at the time) Audi A8.
its shocking just how much difference these little touches make :ph34r:
Thanks Lenny
Just thought there mate,
It will be difficult to get the loom plugs across the A-pillar to the headlining
So instead of splicing in to the ignition loom,
You could cut the loom at footwell length,
This will be easier to fish two cables through the headlining instead of a bulky ignition ring or loom plugs,
Can then rejoin the ignition ring along with the footwell loom together in the drivers footwell once fished through.
+1
Ford have fitted puddle lights to premium models since the early 90's escort I've done a guide on fitting projector puddle lights aswell:
http://www.fordownersclub.com/forums/topic/46244-guide-fitting-ford-projector-puddle-lights-mk2-mk25-focus-05-12-front-doors/
No problem lenny
I had to get brake pads and discs today so when I get them all fitted I will try the ignition ring if I get time.
If not tonight it will be tomorrow.
Thanks again mate.
As promised some pics of my finished installation on the foot wells and ignition ring.
Big thanks to Lenny who help me on this.
I would highly recommend this Mod as its very effective and looks very OEM when finished.
awaiting the birdbath materials then I'm gonna give it a try.
Big thanks to Lenny who helped me on this.
looks fantastic mate,
Those 5 SMD pods look much better than the 3 smd pods ive got fitted to mine,
They dont make the 3 SMD pods anymore hence why i linked the five smd model but they spread the light much better than the three,
Tempted to upgrade those now myself,
Ignition ring and front footwell's are looking great too, i like the genuine ford matts aswell.
The bird bath illumination will compliment the footwells at night too.
I especially like the way it all fades on/off in time with locking/unlocking the car or start/stopping engine.
Thanks Lenny.
The 5 LEDS pods do look well at night. the light is very evenly distributed as well.
I go the mats of ebay as I needed some. I liked the way it had "FOCUS" printed on it.
heres the link
http://www.ebay.co.uk/itm/NEW-Genuine-FORD-FOCUS-MK2-2005-2010-Set-of-4-Tailored-Carpet-Car-Floor-Mat-Set-/160749482670?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item256d6a72ae
Get yourself a set lol!
I like your rear seat cover Lenny. where did you pick it up if you don't mind me asking. I was thinking of getting one as our kids are wee messers in the back lol!
can you get one with just "FORD" on it? since my car isnt a zetec s I think it may look a bit outta place. what ya think?
Thanks Lenny.
heres the link
I like your rear seat cover Lenny. I was thinking of getting one as our kids are wee messers in the back lol!
i definitely will mate they have dropped around 40 pounds since the last time i looked th3m up around three years ago,
Great price now though, roll on Thursday :)
they are a great fit as well. especially the drivers one as it doesn't move all over the place when getting in and out.
should last a good while to.
