nathmogz7 Posted July 23, 2014 Share Posted July 23, 2014 hi people, thought i'd start a thread up regarding snow foam. Which ones do you think is the best on the market? Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted July 23, 2014 Share Posted July 23, 2014 I use demon from Halfords, seems to do a good job :) Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted July 23, 2014 Author Share Posted July 23, 2014 cheers for rely mate. Iva heard good and bad things about the demon one. Does it get rid of all dirt on the car? And some say the foam is not thick enough... Quote Link to comment Share on other sites More sharing options...
Clarky2013 Posted July 23, 2014 Share Posted July 23, 2014 Yeah I would say its good, maybe other products are thicker though, my snow foam routine is pressure wash the car down, then spray on the foam, leave for 5 mins, pressure wash off, gets rid of most of it, obviously the sticky tar and bugs need to be worked separately. Quote Link to comment Share on other sites More sharing options...
Andy199 Posted July 23, 2014 Share Posted July 23, 2014 I use the snow foam from AutoBrite the best stuff I've come across a few of my mates use it aswell with one of there snow foam lances Sent from my C1905 using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
laumk7 Posted July 23, 2014 Share Posted July 23, 2014 I use auto finesse avalanche and it's heaps better than the demon foam IMO You should only be using snow foam as a pre wash though followed with a more intense scrub with a lamb-mitt. snow foam will soften and remove loads on its own but it's not 100% Sent from my iPhone using Ford OC 2 Quote Link to comment Share on other sites More sharing options...
Hatton Posted July 23, 2014 Share Posted July 23, 2014 I use the stuff from Formula Clean, never had a fault with it. http://www.formulaclean.co.uk/snow-foam-and-lance-kits.php Quote Link to comment Share on other sites More sharing options...
MattDRX Posted July 23, 2014 Share Posted July 23, 2014 Demon shine ftw! If I approve it, it must be good right? Sent from my SM-N9005 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
chrisroberson99 Posted July 23, 2014 Share Posted July 23, 2014 Valet Pro snow foam with an Autobrite foam lance! Quote Link to comment Share on other sites More sharing options...
redbull3k7 Posted July 24, 2014 Share Posted July 24, 2014 using valet pro citrus pre clean , used a few different snow foams , valet pro is good and cheaper per wash Quote Link to comment Share on other sites More sharing options...
Jeff4155 Posted July 24, 2014 Share Posted July 24, 2014 I have tried the snow foam method when I purchased the High preasure gun, but to be honest I just use the bucket and soap method, goes alot quicker than setting up the machine to use the soap, and it still doesn't clean as good as I do with a propper wool mit and car wash. PS. I still use the High preassure gun to spray, a standard hose doesn't work better than a High preassure gun. Quote Link to comment Share on other sites More sharing options...
MattJakeT Posted July 24, 2014 Share Posted July 24, 2014 I use demon, going to change soon through. I only use it as a pre wash now tbh. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted July 24, 2014 Author Share Posted July 24, 2014 thanks for all your replies, anyone know where i could get a cheap gun from for the snow foam? thanks in advance Quote Link to comment Share on other sites More sharing options...
laumk7 Posted July 24, 2014 Share Posted July 24, 2014 eBay is always a good bet :) Quote Link to comment Share on other sites More sharing options...
chrisroberson99 Posted July 24, 2014 Share Posted July 24, 2014 snow foam is always better through a pressure washer and foam lance. If you're going to use a spray gun, get some pre wash instead. Quote Link to comment Share on other sites More sharing options...
nathmogz7 Posted July 24, 2014 Author Share Posted July 24, 2014 foam lance i mean mate! any idea where cheapest place to get one from? Quote Link to comment Share on other sites More sharing options...
M4RC Posted July 25, 2014 Share Posted July 25, 2014 Cherry foam Quote Link to comment Share on other sites More sharing options...
