Help!! Cars Under Powered??
Hey folks the past couple of days my car has been giving me alot of greif. When driving to work doing 60mph as soon as i put the car in 5th gear theirs no power and the car drops to 45-50mph with my foot welded to the floor then i have to drop to 4th to get anything out of it. Anyone know why this is? My car is a 2004 1.25 lx 16 valve
Air filters? Spark plugs? Check/replace those. Any Check engine light?
Sent from my iPhone 5 using Ford OC mobile app
Theirs no engine light on. Was going ti give it a good service and see if that helps but i dont know
tried cleaning the throttle body? ive u have a diag mechine check for any error codes, you could also check the enigne oil give it all a clean over, check the fuel filter, like said could try replacing bits at a time and see what cures it, if it carries on after you change and check some bits id take it to somewhere to get a heath check on it
Will try all of the above and if that doesnt work then i dont think its worth doing anything with. Its got 117k on the clock. Be aswell scapping it
Did this just start happening out of the blue?
Found out its my callipers are sticking on. Wondered why i was going through so much fuel haha
