Oil Sump Plug
Oil Change time coming up and I need to replace the copper washer on the sump plug. Anyone know the size of the washer or where I can buy them. As Ford want £8.00 for the bolt and washer.
daz
The sump plug and washer is a one piece part so you can't just replace the washer in afraid. I have reused then many times with no problems
daz
log on to micksgarage.com
Enter your vehicle reg,
They will supply you with the copper washer less than 1 pound,
Bought one off them myself last month and no leaks.
Mine is in two pieces. Wonder if its broke.
Daz
Daz
shoukd be just a washer made from copper and a bolt.
I logged on to Micksgarage.com entered the focus registration plate number,
And up came all available parts for my specific model,
I purchased
Bosh wiper blades,
Oil Sump plug Seal (copper washer)
Bosh Oil Filter
I had previously been to Halfords and purchased a can of Wynne's engine flush for diesels its also available for petrol engines.
IMG_20140511_101944_zpszauv4ri_edit_1399
Micksgarage also supply Castrol oil but its slightly cheaper in Tesco plus you get the Club card points back too.
http://www.tesco.com/direct/edge-fully-synthetic-5w30-engine-oil-4-litre/136-8860.prd
Ive also done a guide on changing the wiper blades here:
http://www.fordownersclub.com/forums/topic/38125-guide-wiper-blade-change-focus-mk2-mk25/
Many of the newer Ford models use a sump plug with a rubber washer. This rubber washer is part of the sump plug and can not be bought seperately. In my opinion the rubber washer can be reused a few times without any problems.
Some older Ford models had exactly the same sump plug but instead of the rubber washer they had a plastic washer which could be bought seperately. This plastic washer is also a perfect fit to the newer sump plugs. Officially the plastic washer are discontinued but many Ford dealers do still have old stock. Last year I bought about 20 plastic washers for a few Euro's. This way I have enough stock myself for future oil changes and do not have to buy the expensive sum plugs.
My 2007 1.6TDCi has a copper washer, 10mm internal diameter, 20mm outer diameter. I have been meaning to replace it for ages but never got around to it and have reused the same one for the last 8 or so oil changes.
The bigger problem I have is that I think I have striipped the thread on the plug - it tightens then suddenly gives and I need to go around another turn to tighten it again. I check the oil level regularly and it is ok, even though there is a slight seep from the drain plug. I might go to Ford to get a new one for the sake of £8 and peace of mind, and get a new washer at the same time.
I haven't seen any ford with a copper washer on the sump plug, didn't know they did! Only ever seen the rubber seal type.
I hope it's the plug you have stripped and not the sump?
Sorry mines a 1.6Hdi Peugeot Partner/ 1.6HDi Citröen Berlingo engine
Ahh yes right enough! That will be why some have a copper washer then?..
