Gear Oil Leak
I have a focus edge 2004 that appears to have a gear box oil leak.
Does anyone know what a garage will charge for fixing this
depends on where the leak is coming from, if its a simple seal at the gearbox oil filter, your looking at a drain renew which could be anwhere from about £70 up
More info required, what engine and gearbox? And as above where is the leak coming from?
Thanks for responses
Have a 1.6 engine with manual gearbox.
Will try to get my head under the car to get a better idea of where the leak is coming from. Have checked engine oil which was at a good level which made me think it was gearbox oil
Have you had any work done on the car recently?
In the end it was a leak from the rocker box gasket. The oil was just working it's way to the bottom of the engine.
Cost just under £80 to fix in local garage ( £42 for 1 hours labour plus the part).
The mechanic says it should be viewed as wear and tear on a 10 year old car.
Sorry for wrongly describing the problem originally.
  • 3 weeks later...
Glad to hear it's resolved anyway.
