Side Light Bulbs
Hi all,
Just a quick question, I want to change my sidelights to match my bulbs that I have used to replace the factory dippee lights and the owners manual states that the sidelights output 5watts of power each
The ones I have seen are 12volts each and I was wondering would these be okay to use to replace the factory ones as most bulbs are measured in volts not watts, as I don't want to melt the wiring loom
All help is appreciated
Thank you
Sent from my SM-N9005 using Ford OC mobile app
All cars work off 12 volts so the bulbs will all be 12v even standard.
What have you replaced your dipped beam with ? Then I can recommend some sidelights according
I replaced my dipped headlights with osram night breakers
I'm trying to get that really bright white light effect :)
Thank you
Try these, you won't be dissapointed :) really good sidelight bulbs.
http://m.ebay.co.uk/itm/321470682857?nav=SEARCH
Does my car use canbas as I can't see it anywhere in the manual aha
Agree with Nathan,,, got them bulbs in mine, and they are the brightest, most white sidelight bulb you'll ever come across.
And I'm pretty sure your car doesn't use canbus.
Doesn't matter if it's canbus the bulb or not, your car isn't canbus so it's irrelevant. Just get the ones linked and as above there the best you can get that I know of :) hope that helps
Fantastic thank you for all your help Mike :)
LEDs generally consume a lot less power so you'll never have to worry about that...
