Egr Blanking Plate
Daft question, but what is a blind hole? I can feel excess material of the bolt sticking through the bottom of the bolt hole in the body.
That is the next idea I have, Jizzer. The stud has a little bit of wiggle space at the moment. I'm hoping that when the engine is cold, the stud and threads of the body will contract enough to let me get it out.
Some bolts would be absolutely amazing! PM inbound.
  • Replies 132
  • Views 26k
  • Nice one Andy, glad you got it sorted. :-D I used to have a Type R too (EP3). Loved it! Sent from under the bonnet
  • Andy.B1971
    Andy.B1971
    Mine was the EP3 too not the starship rubbish FN2, good fun times with the exception of the fuel it drank. :D
  • Andy.B1971
    Andy.B1971
    No light on this way either on my dash or upstairs
When the stud does nor fo all the way through ie only taped a partial way in the valve if ir comes out the other side as previously suggestions drill out and nut and bolt
Sent from my GT-I9100 using Ford OC mobile app
Dont no if this helps but on my 1.8 tdci i took off the intercooler pipe to get better access to my egr if its at the back of the engine like mine
Pics might help.
when I had a timing belt change years ago the bolts snapped off
Wow dude bet that p1ssed u off
Hello, folks.
I've only gone and managed to get it out! It was sticking out of the valve a bit and was removable by finger tip! Lucky lucky lucky!
Jizzer, I can't thank you enough! I'll be using a couple to replace the one I have left (as a precaution) and the 7cm bolt I have keeping things secure for the mean time.
You really don't need to use that much effort to close the join up to make a seal.
And for the record, should anyone ever need new bolts, the shaft is 25mm long and an M6 thread.
Nice kye at least it wasnt as bad as you first thought drilling it would of been a nightmare
  • 5 years later...
Hi...just wonder where do u blank....the round circle or other hole
