Glove Box Fuse
Just wandering how difficult it is to change the fuse for the glove box on a mk2.5? I have no light! Any help is appreciated guys
Reach under the glovebox and find two yellow catches.
Turn them counter-clockwise and the board will hinge down.
Pull the board towards you and allow the rear hinges to drop into a notch on the brackets and tje board will fold down flat for easier access to the fuses.
When finished fold up the board and lift the rear of the board up, pushing back so it drops into the hinge notches again.
Raise the board fully, line up the catches, push up as you turn clockwise.
There is a mk2.5 fusebox diagram linked under this post (viewed on a PC).
Sent from my SM-G900F using Ford OC mobile app
Ah ok thanks for that Stoney much appriciated! So what fuse will I need to replace and what sort, to get the interior lights/glove box light etc working again!?
It will be a mini fuse.
Location and amp rating in the fusebox diagrams on my links.
Cheers mate appreciate the help! Have gone and ordered myself some 10 amp mini fuses for 104 ;)!
