Lee Oyston Posted August 8, 2014 Share Posted August 8, 2014 Hi I have a 08 fiesta zetec mk6 The problem I have is the gear box when the car is running it is really hard to get it into gear 4 and 5 are just as usual to put into gear, once it is in gear it is just as normal it doesn't just jump out, when the car isn't running it is going into gear fine, I had my clutch done in my car approx 2 months ago don't know if this can change anything but can anyone help me thanks Quote Link to comment Share on other sites More sharing options...
DieselPig Posted August 8, 2014 Share Posted August 8, 2014 Sounds like the clutch is dragging. 1 Quote Link to comment Share on other sites More sharing options...
MAJE5T1C Posted August 8, 2014 Share Posted August 8, 2014 This is normally due to having the wrong oil in the gearbox if your clutch has been done recently the oil will of come out of the box trough the drive shafts holes as they have to be removed to do the clutch Drain the oil from you gearbox not easy as there's no drain plug then refill with fully synthetic 75-90 and it will be fine Quote Link to comment Share on other sites More sharing options...
Lee Oyston Posted August 9, 2014 Author Share Posted August 9, 2014 Thanks a lot! I will get this sorted soon my biting point on my clutch is right at the vroom I have to lift my toe up and it bites if this hella Quote Link to comment Share on other sites More sharing options...
