Jonnyb Posted August 9, 2014 Share Posted August 9, 2014 Hi guys i'm new here. Just bought a 2000 escort 1.8TD i was running a reno megane DCI, never again though. I would like some Ford expertise on this matter if possible. The escort drives ok but on acceleration it tends to pull to the right and when i let off it goes back to the left a bit like torque steer i suppose, but can't see it being that on a Diesel unless i'm wrong as usual. Cheers Jon. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 My focus diesel as more torque steer then my mk4 did lol are brakes Binding on left ? Sent from my HTC One X using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 I don't think they are but i'll check, it seems to pull ok power wise, does your focus pull to one side with torque? Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 Mine is also tddi and Pulls to right very slightly put it's maxxed out running 311nm torque Sent from my HTC One X using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 as far as i'm aware mine is just std, and it pulls quite a bit to the right on acceleration seems to ever so slightly lift as well then when i left off the power it goes back to left its weird. Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 No play in trackrods ? Sent from my HTC One X using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 No doesn't seem any, but think i better jack front end up and check bearings etc.. tbh I've never had a car do it before I didn't know if it was a common fault on escorts. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 No cars should do this lol. As car been in a accident ? Sent from my HTC One X using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 Not sure on that either and didn't do HPI. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 It gets overlooked on older cars sadly. If it was my car is check all bushes and balljoints then brakes and carriers. If all that is fine I'd look for accident damage. Sent from my HTC One X using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 Thanks for that pal I appreciate your time. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
AJRTDDI Posted August 10, 2014 Share Posted August 10, 2014 No worries if u was more local is had alook for you. Good luck Sent from my HTC One X using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 10, 2014 Author Share Posted August 10, 2014 Thanks pal. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
vinnyvangough Posted August 11, 2014 Share Posted August 11, 2014 99% it will be your lower arm bushes. Common as muck fault. Jack it up and I bet you'll find the rubbers are shot. Easier to buy 2 new complete arms than go through the hassle of changing the bushes. Cheap and easily changed in an hour or 2. 1 Quote Link to comment Share on other sites More sharing options...
Jonnyb Posted August 12, 2014 Author Share Posted August 12, 2014 Cheers Vinny ;) i'm going to have a look at the front end on the weekend. 1 Quote Link to comment Share on other sites More sharing options...
