scottyrb Posted August 10, 2014 Share Posted August 10, 2014 Hi quick question does anybody have any idea on how to remove the grey plastics from the front and rear bumper ie the fog light covers Sent from my iPhone using Ford Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 10, 2014 Share Posted August 10, 2014 They literally just pull off, start from one corner and pry it away then give thema good tug and the tabs will pop out. Quote Link to comment Share on other sites More sharing options...
scottyrb Posted August 10, 2014 Author Share Posted August 10, 2014 Really it's that simple with all the grey plastic bits ? Sent from my iPhone using Ford Quote Link to comment Share on other sites More sharing options...
Nathan54771 Posted August 10, 2014 Share Posted August 10, 2014 I'm pretty sure it is yeh, definately the case with the other trim levels because I've done it on my zetec s. Not got my st-3 yet so can't tell you :( but I'm sure it's the same ? can't see it being bolted or screwed in. A way to check is turn your wheel to full lock and undo the two screws holding your wheel arch in, move it out the way and look in too see behind the fog light plastics :) Quote Link to comment Share on other sites More sharing options...
scottyrb Posted August 10, 2014 Author Share Posted August 10, 2014 I will do thanks a lot Sent from my iPhone using Ford 1 Quote Link to comment Share on other sites More sharing options...
