Focus Speedo Stops Working
My 54 plate Focus 1.4 has a problem that the speedo stops working and the mileage readout becomes four dashes,then sometimes the engine management light comes on as well-the fault reader said it was a speed sensor?.Anyone any ideas .Thanks
It does sound like the VSS.
when the problem occurs do you find that the engine power dips a bit as well?
A VSS is about £15-£20 on ebay with a new mounting pin (essential as the old one will get mangled when being removed).
It can be a swine to remove the old unit and pin but is doable at home.
If in doubt go to a garage, it's about an hours labour.
In extreme cases the sensor or pin can snap off making the job harder, having all the right kit is useful in these cases.
http://pages.ebay.com/link/?nav=item.view&id=151303513104&alt=web
Sent from my SM-G900F using Ford OC mobile app
