Fault Reader/dignostics
:wacko:hi everyone , a really big ask but does anyone in the Bolton area have a fault / diagnostic machine be able to come to mine and plug in my 06 focus 1.6 climate , only bought it yesterday of a old couple who left it sat with a flat battery for 6 months ive put new battery on and new battery in fob all central locking works ,lights windows etc but turn key and nothing..... dash say engine systems fault , the couple said it was running perfect when parked up any ideas ???????????????? :wacko:
Ive seen this before, when you turn the key does the red light in the middle of the cluster flash like crazy?
If you tow/push start the car it will run, the reason it wont turn over is when then battery died the car started to throw up fault codes, these are all stored and until they are cleared the car wont start naturally using the key.
stupid i know but they is what happens if the car has been dead for a while, im not near you so i cant help with the clearing sorry. im sure someone else could
yes the red light does flash crazy , so if I can get someone to clear the code will it start on key ???
Yeppppp! Turn it on and off a few time to see if the red light will stop being a muppet. That's for the immobiliser. Then it may start with a push or tow.
However codes need clearing!
Sent from my iPhone
what if the red light doesn't stop flashing ???
Then it's not starting till the codes are cleared, it's also possible the car/key has lost the link so may needs re-coding
Sent from my iPhone
is that a ford job then ???
No you should be able to find someone in your area to do it. First things first, get the codes cleared and go from there. I know this must be annoying
Sent from my iPhone
thanks for your help pal ill keep you posted :D
Good luck mate
Sent from my iPhone
