callmecheez Posted September 2, 2014 Share Posted September 2, 2014 Anyone done this? What's the cheapest way? Made some enquiries today, and cheapest I found was a place who would fit an aftermarket (non-ford) cruise control for £445, which is quite expensive. Thanks in advance! edit: I should add- I have seen the guide in the 'Guides' section, but it looks complicated and way beyond something I could attempt. Quote Link to comment Share on other sites More sharing options...
Focus66 Posted September 2, 2014 Share Posted September 2, 2014 I did mine, got the software and correct 2 speed cable and activated on the car (06 1.8TDCi) You will need to source a correct steering wheel with cruise controls for a Focus 05>11 (Not a C-Max) Got mine from eBay for £100 I'm in N.Yorks, if you need any help with activating the cruise control on the car I may be able to help. I just followed the instructions on the thread and it works perfectly. One of the best things I've done. Quote Link to comment Share on other sites More sharing options...
callmecheez Posted September 3, 2014 Author Share Posted September 3, 2014 I did mine, got the software and correct 2 speed cable and activated on the car (06 1.8TDCi) You will need to source a correct steering wheel with cruise controls for a Focus 05>11 (Not a C-Max) Got mine from eBay for £100 I'm in N.Yorks, if you need any help with activating the cruise control on the car I may be able to help. I just followed the instructions on the thread and it works perfectly. One of the best things I've done. Thanks for the reply Ian, that's encouraging. Couple of questions for you if you don't mind; How can I find out if I can actually activate it on my particular car? I've read another thread where it came to activate it, and the option just wasn't there? Is changing the steering wheel difficult? Are there any issues with the airbag? When you enable CC - is there any light on the dashboard - this isn't a dealbreaker in the slightest, I just wondered! Thanks! Quote Link to comment Share on other sites More sharing options...
Focus66 Posted September 3, 2014 Share Posted September 3, 2014 Hi Chris 1. When you connect to the car the software gives you options to "tick" box's to activate cruise control and save. 2. My original steering wheel was a 3 spoke design, luckily the 4 spoke wheel with CC fitted also came with the 4 spoke airbag. I followed the instructions from Haynes manual, taking the fuse out first as a precaution. I fiddled about a bit then suddenly got the Technique to release the spring catches holding the airbag in place. 3. Depending on which dash board you have !? Mine doesn't have a CC light, but the CC works perfectly. Most Focus do have the Light, my hand book shows the 2 different instrument clusters. Entering the "instrument cluster diagnostic mode" will confirm if you have the light there or not. TBH the hardest thing will be getting hold of the wheel. Quote Link to comment Share on other sites More sharing options...
