w2575 Posted June 23, 2009 Share Posted June 23, 2009 Had the system charged Febuary 09 at ford dealer. When the a/c is switched on a whining noise starts . i dont know if its the evaporator or compressor anyone have the problem or know any more about the systems ? Quote Link to comment Share on other sites More sharing options...
alz Posted June 23, 2009 Share Posted June 23, 2009 could be the drive belt sliping, try and spray some wd40 on to the belt, if it stops whining then the belt needs to be changed,,this is a good place to looking as belt are cheap.. Quote Link to comment Share on other sites More sharing options...
Big Bob Posted June 28, 2009 Share Posted June 28, 2009 could be the drive belt sliping, try and spray some wd40 on to the belt, if it stops whining then the belt needs to be changed,,this is a good place to looking as belt are cheap.. I would suggest that if you spray WD40 or any other lubricant onto the belt then it will need changing! Check the condition & tension or dust the belt with talcum powder, this is a mild abrasive & should take any shine off the pulley & give the belt more bite. Quote Link to comment Share on other sites More sharing options...
