steve67 Posted June 23, 2009 Share Posted June 23, 2009 hello, i have a 51 plate tddi focus, on start up first thing in the morning i have a small squealing noise from the engine that lasts for about 2-3mins and then disappears. any ideas? it's only in the morning!!!! Quote Link to comment Share on other sites More sharing options...
Whelk8891 Posted June 23, 2009 Share Posted June 23, 2009 hello, i have a 51 plate tddi focus, on start up first thing in the morning i have a small squealing noise from the engine that lasts for about 2-3mins and then disappears. any ideas? it's only in the morning!!!! Auxiliary belt, probably. Its a common complaint. Its a flat belt and when its worn, it can slip against the pulleys causing a squeak. You can get some stuff to spray onto the belt to give it better adhesion, or you can replace the belt - better done at a garage cos I gather its not the easiest of maintenance jobs, plus the belt needs to be the right tension after refitting. Quote Link to comment Share on other sites More sharing options...
steve67 Posted June 24, 2009 Author Share Posted June 24, 2009 Auxiliary belt, probably. Its a common complaint. Its a flat belt and when its worn, it can slip against the pulleys causing a squeak.You can get some stuff to spray onto the belt to give it better adhesion, or you can replace the belt - better done at a garage cos I gather its not the easiest of maintenance jobs, plus the belt needs to be the right tension after refitting. thanks for that, the car is in for a major service next week , i'll get them to take a look. Quote Link to comment Share on other sites More sharing options...
