Coolant Leak From Joint In Engine.. Help !!!
Hi all
Wondered if anyone can help me
Im loosing water daily and sometimes way beyond the min mark in collant tank, I have looked everywhere and the only place I can see it leaking from is from a joint to the engine (photos attached)
I don't know what part it is and can I get a replacement gasket to go on this joint ?
Or maybe make one ?
I take it I would have to drain the coolant too before removing the joint ?
any suggestions would be most appreciated :)
Cheers
Rich
post-23919-0-71326500-1410336480_thumb.j
post-23919-0-68687100-1410336492_thumb.j
post-23919-0-66725900-1410336509_thumb.j
Not sure what that joint is but it shouldnt be leaking from the engine mate that would suggest major problems hopefully a diesel owner can identify that area
is that not the thermostat housing? cant be 100% because of the close up but it could be that the thermostat housing and gasket needs replacing
