Uo118 Fault Code
Hi I'm new to this so I hope I get this right. I own a 2005 focus estate 1.6 tdci. I have a recurring fault code on my car and am looking for any info on this problem ie the code says lost communication with fuel addative control module. Has any one had this problem. How can I fix it
sounds like a bad bit of wiring to the EOLYS fluid tank,. You need to get under the car, look straight up the side of the fuel tank and find the extra pipe that goes in, then follow that back and you should find an electrical connector. make sure its connected tightly.
Ok I'll try that thanks
Good luck let us know how it goes
