Reverse Gear
Hello!
I got a Ford focus 2 facelift 1.6 petrol 100cp, and when i put in reverse gear, sometimes it gives a sound like i didnt put in reverse gear correctly?
What could the problem be?
THanks!
please ?
There probably is not a problem. I don't think reverse gear has a synchromesh on it. Try pressing the clutch a couple of times before selecting reverse. Mine use to be the same on my fiesta and when i started to push the pedal a couple of times it was fine.
Also, try waiting a second or two between depessing the clutch and engaging reverse. This will allow the clutch driven plate to stop spinning.
Thank You, i have my Focus for a month now and i was scared a bit :)
Its a trait of most Fords. As said there is no syncro on reverse.
I wouldn't call it a problem though. Make sure the car is not still moving forward before changing to reverse then wait a second or two
Okay, thanks guys :)
Not just a Ford issue!! Fiat are the same
As said, it's a "Fordism" and the above advice is spot on :-)
