Parrot Hands Free Installation
Hello,
I recently bought a Parrot ck3100 kit from ebay to fit to my mk2 focus , I also bought the correct SOT ISO lead, tried fitting it all together today and get the radio to power back on but no signs of life from the Parrot system. Has anyone fitted this to their mk2 and if so can they please help me through this
I have a ck3100 however it was in the car when I bought it.
Have you checked all the connections are tight?
As a note- if you get power to the box and anything after that is not connected properly you will get a rapid pip sound from the speakers.
Also double check that the SOT cable is correct.
The Vauxhall and Ford ones are identical except for the ignition and battery wires are reversed.
Ford cable should be SOT-092(S) and the Vauxhall one is SOT-122(S)
I have the SOT092S cable, connect everything up, connect the looms up but the parrot does not power up no sounds, no lights. Would rather do this myself rather than get someone in to install it
Just a clutch at straws but have you tried connecting the loom to the radio, powering it up and THEN connecting the Parrot box?
Worth a look.
