NL06NKA Posted September 24, 2014 Share Posted September 24, 2014 Hello all I have just bought 18" alloys for my Ford Focus MK2.5 and I am wondering if I am going to face any problems once they are fitted ? Will the spring rub off them ? Will I be able to turn my wheel fully ? Any other info would be appreciated Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
luke.grimbley Posted September 24, 2014 Share Posted September 24, 2014 Hello all I have just bought 18" alloys for my Ford Focus MK2.5 and I am wondering if I am going to face any problems once they are fitted ? Will the spring rub off them ? Will I be able to turn my wheel fully ? Any other info would be appreciated ImageUploadedByFord OC1411585571.293124.jpgImageUploadedByFord OC1411585601.106703.jpg Sent from my iPhone using Ford OC What width are they? Ford recommend when fitting 18x8.0 wheels or bigger that you fit the steering limiter kit. It's not expensive, basically just a ring that prevents full lock. Quote Link to comment Share on other sites More sharing options...
NL06NKA Posted September 24, 2014 Author Share Posted September 24, 2014 The width is 8J I think ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 24, 2014 Share Posted September 24, 2014 Definitely need a limiting kit or else you will catch the arch liner and arch on full lock. Quote Link to comment Share on other sites More sharing options...
NL06NKA Posted September 24, 2014 Author Share Posted September 24, 2014 Will I be able to do a full lock with the limiter on ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
luke.grimbley Posted September 24, 2014 Share Posted September 24, 2014 Yeah, 8J stick the limiting kit on. As Stoney said you will be rubbing on full lock. I'm sure it's about £20 from Ford. Quote Link to comment Share on other sites More sharing options...
luke.grimbley Posted September 24, 2014 Share Posted September 24, 2014 Will I be able to do a full lock with the limiter on ? Sent from my iPhone using Ford OC No the limiter is to prevent full lock. The ST/RS come with it as standard. If you go to full lock with the 8J wheels they will rub on the arch liners. Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 24, 2014 Share Posted September 24, 2014 You only lose a small bit of lock but you gain kerb appeal ;) 1 Quote Link to comment Share on other sites More sharing options...
NL06NKA Posted September 24, 2014 Author Share Posted September 24, 2014 Ok so you know how much they are roughly and how do you fit them Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 24, 2014 Share Posted September 24, 2014 They're about £15 and you need to order Finis code 1342639. Remove the wheel and then unclip the steering rack gaitor.Turn the steering full lock and then clip the limiter/bush over the steering rack pinion (at the end of the teeth/grooves)Re-fit the gaitor using one of the new clips as the old one will usually get damaged.Turn the steering full lock the other way and repeat this procedure.There is usually a small diagram in the kit when you buy it from ford.On the Focus there are already limiters/ bushes fitted but these need to be removed and changed with the new ones. Quote Link to comment Share on other sites More sharing options...
