Focus Ecu Reset & Learn
sonic113
ok I have been reading a few articles on resetting the ecu of a car and how it may help various things like mpg and stuff like that.
I have decided to give this a go as I want to see for myself if it makes any differences. To be clear my car is fully serviced and running 100% only iggle I have is a slight lack of pull/throttle feeling when I'm pulling on hills ect. So I decided to try a reset first just to see.
The aim of this test is basically to see if any difference can be noticed in any way or form.
I can not find a guide of sorts but I plan to do the following:
1)Disconnect battery Negative terminal.
2) Let car sit for 1hour to discharge all.
3) reconnect Terminals
4) Start car allow to idle for 10 - 15 min without touching accelerator
5) Take for a drive and drive the way I normally do
6) Continue my normal driving style throughout the week/Month and see if there is any kind of difference at all.
any Input here would be greatly welcomed and encase any one suggests yes I do have the radio code so don't worry lol!
I Read that James (Jeebowhite) has reset his mondeo and I think his cmax and he noticed an improvement in the mpg and I have also read that some people suggest a reset after each service or change of a senor, air intake as in a sense this changes the environment of the engine (example new or updated air filter will allow more or clean air through so ecu can adjust or alter other things to suit this change in the engines environment ect)
Now to be clear I'm not saying this works or does not work I'm just restating what I have read and heard from others hence the reason I would like to try this out for myself.
so any advice or input is greatly welcomed here and hopefully by the end we should all have a good insight in how the ecu works and if a reset actually does or may help.
Thanks for reading.
Well, what harm can be done!
Mines a little low on where id like its MPG to be, probably because I thrash it every now and then to "make sure its ok" :)
Be interesting to see if you could actually map this out using forscan on a laptop and a EML327, getting two idle data sets would be easy, getting two driven tests might be a bit harder. Might help with spotting differences rather then "feeling" them though
Just disconnecting the battery doesn't reset all the data the ECU holds. To do a full reset, disconnect the battery negative, run a jump lead from disconnected and isolated negative plug (not battery terminal) to positive terninal/wiring). Apparently doing that for a few minutes drains any capacitors in the loop, causing everything to reset, which doesn't necessarily happen just disconnecting the battery. Stuff like pedal position sensors and automatic gearbox shift points all get reset using this method.
Another way may be to disconnect the battery while the ignition is still on - that way the ecu drains any capacitors itself before it fully powers down.
On the ST there is a specific fuse you can pull, leave out for 30mins or so then replace which supposedly resets the ECU. However in the past when I reloaded a bluefin map onto one of my cars, the first time I put my foot down it blew the clutch away. No long lasting damage done but it did stink for a bit.
Also know someone who monitored a ton of running data after resetting ECU (ST again) and the car wasn't fuelling very well etc for quite a while till it settled down. May have felt sharper to drive but not actually the case.
Disconnecting a battery on a running engine can/will do a LOT of damage to relays and ECU's. DONT ever do it. The battery is the largest smoothing capacitor on the car
Still not a good idea, you don't pull the plug on your computer while its running, you shut it down first, Any damage will not be warranty covered as the user manual explicitly says never to do that
These cars are not like the old ones, where ignition on just was a 12v feed, nowadays the fuel pump runs to prime the rail, lots of solenoids are activated, cpu's powered up and running code in the background, Physical systems like EGR, wastegate, shutters etc are cycled and tested for operation etc Plenty of things going on that a dead kill in the middle may not be recoverable
Also with the puters on board now, even resetting the ECU is not like the old cars where it forced a relearn cycle on the idle timing and fueling over the next few run cycles. Yes it will drop some tables to be relearnt but many of the new tables average over large numbers of run cycles (say 20) so optimum run condition may not bee seen again for some time. That's why I cringe every time I see someone say unplug it to reset the puter. Its just not that simple anymore
Ok little update here. I did this yesterday and drove 6-7 journeys ranging from 5mile to 35 mile a journey being from car start to car stop lol! and I don't know what to say really.
I did notice a slight difference on each journey kind of like the car adjusting or something but on each journey I tried do the same thing in regards to my driving. I changed gear around 2250 rpm and used the throttle as I would under normal driving. also when coming to a stop I gently slowed the car down using the brakes and gears where as before I would of been a bit more of a "just stop" guy lol!.
Now this morning I have noticed that the car does feels a little more smoother and pulls more smooth on inclines but I don't know if I can truthfully say it has made a major difference but I would go as far as saying it has made some maybe although I do believe that I need to do some more journeys to see how it maps out. I think that through a few more journeys of my normal driving the car may settle from the reset and I may or may not noticed anything but I guess time will tell.
  • 4 years later...
Will a reset do anything towards a DPF clean???
  • Confused 1
No.
  • Like 2
  • 4 months later...
Hi sonic113, did you manage to reset the ECU of your Ford Focus by following the steps above? If so, did it help with reducing lack of pull/throttling up the hills that you have mentioned? Thanks
  • 1 year later...
My 2014 ford focus zetec keeps going in to limpmode no warning lights come on the dashboard or no problems shows up when my mechanic puts the dynastic computer in he think its something to do with uce needs flashback or resetting anyone had problems like this before?
  • 7 months later...
Hi my son has a Ford ka, he wanted his car to pop and bang, some lad came down and said he could do it, but now the car won't start, he has told us that a guy has bench it, but it's still not working any ideas
My Ford focus is getting10 mpg ,2000cc fual injected 2007 what's up ! How do I improve the mpg
Reflash with the OEM map
10 MPG?? I would definitely stop driving with the handbrake on! 🤣
