Front Electric Windows Help Wanted
How do I get the one touch window up to work again? my drivers window doesn't do it but the passenger window does.
I recently fitted wind deflectors & this may have caused it to not work anymore.
Thanks in advance.
Mark.
Solved by Nathan_M
  • Solution
Do the deflectors make the window fit tight into the seals perhaps the window motor thinks its got fingers trapped or something along those lines?
The window goes up & down ok. The one touch down works ok but the one touch up doesn't work & the anti trap works ok too.
When I fitted the deflectors the anti trap activated a few times but is ok now.
Mine did this yesterday (recently fitted wind deflectors too), you need to fully close the window, then hold the up position on whichever window it is for about 5 seconds. It should reset it.
Yep, just reset it. Put the window up fully and keep holding it for a few seconds, then do the same for down. If it doesn't work repeat the process a few tines
I take it you can't train a 5 door with only front electric windows?
Mine is a 5 door.
It is fixed now, I just gave the wind deflector a little wriggle & now the 1 touch up works again.
Thanks guys!!
Ahh sorry was thinking about auto close and open which on 5 doors is only on models with rear electric windows. Wondered if it's possible to activate for front only windows on a 5 dr.
