Reassurance??!!! Metal Mk7
Added a induction cone filter to my metal. I left the box of panel in there (without lid) for the cone filter to rest on. Just want to make sure I done this right??
If so any tips what to do next added this and bluefin superchip also had miltek exhaust system what next to do ? Cheers.
Get shot of the cone filter I'd say ;)
Why ? It sounds good.
They do indeed but suck in the hot air from under the bonnet and reduce proformance.
Along as you have a cold air feed going to it, like te OE one from the slam panel it will be fine. Once the car is moving there is cold air under the bonnet.
Going to put panel back on then, cheers. Will just change the hose to s pumaspeed one
Heat soak isn't a major issue on the ZS.
What filter have you used?
J1 cone
