Reverse Lights
Hi guys need help! On my fiesta 55 plate the reverse lights aren't working. I've changed the bulbs and checked the fuse but both fine.
Need help! MOT due next month!
Sent from my iPhone 5 using the Ford OC app.
For the reversing light, there is a switch on the gearbox that will power the light directly (no relay), the only relay in the circuit will be the one that supplies power to the fuse which you said is fine, so it could possibly be the switch that needs replace, Also you don't need a working reverse light to pass your MOT.
Oh I didn't know you didn't!(thanks!) and I've got it in for a switch replacement after asking my mechanic he thinks it's that too! Thank you for your help!
wat bout relay
wat bout relay
or even reverse light switch
