St Brakes
Not sure if anyone has asked how much this is from Ford.
Just Called them up and got prices.
Front Pads £66.31
Front Discs £125.11
Rear Pads £63.55
Rear Discs £101.28
All in well over £350 quid just for the parts.
( Old Clio 182 was about £190 all in using Brembo and Ferodo )
Anyone doing an Oil change there is no Washer with the filter as the car has an Oring on the plug, don't try and buy these from Ford instead use ebay for an Oring, Plug only by itself is £10.16
Just got 4.1 litres of Oil and Filter from them at £37.33 all in which isn't too shabby.
Later on services touching the brakes is going to be dear.
EBC, Ferodo and Brembo hurry the !Removed! up please.
Have you worn your brakes out already? If so I'm mightily impressed
I've considered a brake upgrade to mountune or similar with bigger discs and calipers as I think the brakes tend to fade sometimes.
Sorry forgot to ask how many miles you got from them?
Had a look on EBC direct and there does seem to be ST pads available, however, the prices are eye watering..
Pads for the ZS at the front are much more reasonable. I'm lucky enough to get a significant discount, so may upgrade when the time comes.
