Finally... St170 104Pin Oem Ecu Pinout.
Ecu code 3NFA
03 white/red--IMRC pin4
09 white/black--Barometric sensor pin 3
12 black/white –IMRC pin 3
13 orange/black--DLC pin 13 modal program.
15 blue/black-- DLC pin 10 scp-.
16 grey/orange-- DLC pin2 scp+.
17 black/white – high speed fan.
19 grey/orange -- Pats TX signal.
20 black/blue -- Injector 3 switched earth.
21 white/red -- crankshaft position sensor +.
22 brown/rd --crankshaft position sensor -.
24 black/yellow -- earth.
25 black/red -- earth.
26 black/orange – coil pin 1.
27 black/red -- start inhibit relay.
28 white/violet – telemetric.
31 black/yellow -- Power steering pressure switch.
32 brown/yellow—knock sensor pin 1.
35 white/red— HSO2 1 pin 4.
36 brown/blue -- MAF pin 4.
37 white/green—fuel rail pressure switch pin 1.
38 white -- coolant temp sensor pin 1.
39 white violet -- Air temp in MAF pin1.
40 green/black -- fuel pump driver pin 7.
41 green/yellow -- A/C clutch pressure switch.
42 black/orange -- PATS Led.
43 white/blue –- Trip computer.
45 black/red—vvt solenoid pin 2.
46 black/green—Engine run relay
49 blue/red—DLC pin 14 can-.
50 grey/red—DLC pin 6 can+.
51 black/yellow -- earth.
52 black/green -- coil pin 3.
53 white/green -- Pats RX signal.
54 black/white -- fuel pump driver pin 1.
55 red-- KAM perm live.
56 black/blue—evap pin 2.
57 white/black—knock sensor pin 2.
58 white/blue -- Vehicle speed Sensor pin 2.
59 grey – Alternator pin 1.
60 white -- HO2S 1 signal
64 white --clutch switch.
68 black/blue – engine cooling fan.
69 black/yellow -- Ac wot relay
70 black/white -- injector 1 pin2.
71 green/yellow -- switched 12v from power relay.
72 blue—alternator pin 2.
76 white/violet -- Cam position sensor pin 1.
77 black/yellow -- earth.
83 green/yellow -- idle air control valve pin 2.
85 brown/white -- camshaft position sensor pin 2.
86 white/red -- Ac high pressure switch.
88 white/blue -- MAF pin 5..
89 white -- throttle position sensor pin 2.
90 yellow -- 5v Voltage Reference (5v out from ecu)
91 brown -- sensor common brown
93 black/yellow -- HO2S 1 heater control.
95 black/orange -- injector 4 pin 2.
96 black/yellow -- injector 2 pin 2.
97 green/yellow -- switched 12v.
100 black/blue – HO2S 2 pin 2.
103 black/yellow -- earth.
Important Sensor & transponder pinouts in link below. So glad I found that thread :)
http://www.locostbuilders.co.uk/forum/viewthread.php?tid=190440
