willc Posted November 9, 2014 Share Posted November 9, 2014 Hi, My ESP light csme on the other day and i cant switch it off!! Tried tick or unticking it from my control menu but not having much luck. Anyone experience this issue? Is my ESP unit knackered?? Thanks Will Quote Link to comment Share on other sites More sharing options...
willc Posted November 9, 2014 Author Share Posted November 9, 2014 Oh and i have a fault code reader, it came back fsult code C1288- chassis... ? Quote Link to comment Share on other sites More sharing options...
JW1982 Posted November 9, 2014 Share Posted November 9, 2014 DTC C1288 is related to the pressure sensor of the ABS / ESP pump. This is a known problem of the ABS / ESP pumps that are used in the Focus MK2 / MK2.5 (and many other vehicles). The solution for this problem is replacing the hydraulic part of the pump. On some ABS/ESP pumps it is only possible to reclame the complete pump. There are also specialized companies which can repair/rebuild the defective pump. They will replace the weak parts which are known causing this problem for uprated parts. Quote Link to comment Share on other sites More sharing options...
troy45 Posted November 9, 2014 Share Posted November 9, 2014 As I understand it Ford used to only supply the complete ABS modulator, for a rather hefty price. But now they do sell the components needed to repair your existing unit when the pressure sensor has gone belly up. Quote Link to comment Share on other sites More sharing options...
shaunytee1600 Posted November 9, 2014 Share Posted November 9, 2014 If you look at my post it may help because I had this scenario on my 1.8 tdci 2009 focus. Power is nothing without control . Quote Link to comment Share on other sites More sharing options...
