Fiesta Finesse 2002 (52) Rh Rear Light Assembly...
...having problems with boot leaking in water, at the moment the only thing I can think of is the lower screw that attaches the light assembly to the body work just keeps turning, it isn't gripping or tightening onto anything. I hadn't noticed until bulb changing.
I don't know how to get behind and see what it should be fixing to.
Any advice welcome, thanks.
A screw wont be there to stop water ingress, it's be a seal someone where or worse a hole, take the carpet out and check the boot seams on the floor and check the rubbers all around the boot door.
I'm sure the water is coming in from the bottom of the light cluster area, should the the lens cluster have some kind of gasket?
Thanks.
