Parts Chart/numbers
Looked around on here but cant seem to see one if there is.
Is there a parts chart/numbers somewhere,shows you the part with the number like ford has.
I'd also be interested in this... I use Servicebox a lot for Peugeot parts and can't seem to find anything similar and free for Fords?
It's called eCAT but it's only for dealers. Think there's also microCAT but unsure if it's publicly available.
Wish you could get it some way,even buy it.
Microcat is available as a downloadable file.
I'll share the link shortly (along with the start-up guide).
Be aware that it is date expired (New version not available yet) but will work fine if you set your computers date to 02/11/14 prior to installing and every time you run the programme.
If you don't change the date then an expiration box will pop up and the programme will close.
Cheers Stoney! I'll save that to the 'car' laptop later. Can keep the date set wrong then, will only confuse myself if I do it on this one haha!
Once the newer version is available it can be installed over the current version and no time travel will be necessary ;)
If microcat isn't an option you can try one of several websites (usually Russian) for ordering Ford parts - these use the parts diagrams to give FINIS numbers etc but tend to lack the detail needed if there's several variants of the same type of part such as trim colours etc.
http://eucatparts.com/?action=cat_ford
If you got an updated version stoney let us know.
I will do.
If anyone comes across the new version let us know.
Thanks a lot stoney,like said above will put on other pc.
Cheers
Cheers
Stoney....when you install and opens up how do you change it to english as there are 2 long boxes
to fill in and i think the ok/confirm under them but not in english.
Dint work on windows 7 but opened A1 on xp just the english problem.
I find that if the ok button is not obvious the best way to proceed is to just hit the enter key.
So dont fill anything in just press enter as can't understand what you should fill in the 2 boxes lol
Can't read jap :D
Did you follow the PDF guide I added to the Microcat files?
Sorry,did sort the time out and stuff,will have a look.
Yes its there, :iim: Me
This is dam good,can't get it working on windoes 7 64bit but all great on xp.
