tivyguy01 Posted November 23, 2014 Share Posted November 23, 2014 Today i have noticed a rumble from the rear while driving. mine is the mk2 foci 2005. Im guessing maybe a wheel bearing. Found on eurocar parts and expensive.. Not had any tyres changed but not heard it before.. Any ideas please people.. Thanks Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 23, 2014 Share Posted November 23, 2014 Wheel bearing is usually a constant whine varying in pitch depending on speed not to say it's not the bearing where you driving on a road you don't usually I know when I go through Stoke on Trent there a section of road there that makes it sound as if the bearings have gone but it's just tyre noise .possible if you have two different tread patterns might sound as if it's coming from only one wheel Have you jacked the car up at the rear and spun the wheel by hand to see if you can hear any unusual noise If it does need replacing I suggest you soak the bolts in plus gas as they can be a pain to release that's assuming it's the same set up as the mk1 where you replace the hub. Quote Link to comment Share on other sites More sharing options...
tivyguy01 Posted November 23, 2014 Author Share Posted November 23, 2014 Iv driven down that road many times. It appears to get louder as i got faster. Havint had time to jack it up and spin wheels. its had same tyres since july but never heard the noise. Today the humming noise was very loud.. Can i replace just one bearing or do i need to change both.. if it is bearing. Thanks Quote Link to comment Share on other sites More sharing options...
STEADS Posted November 23, 2014 Share Posted November 23, 2014 Sounds like the bearing yes you can just replace the one almost certain you will need a torx fitting for the original bolts not sure what size but they can be a real pain to release . Quote Link to comment Share on other sites More sharing options...
stef123 Posted November 24, 2014 Share Posted November 24, 2014 Wheel bearing is usually a constant whine varying in pitch depending on speed not to say it's not the bearing where you driving on a road you don't usually I know when I go through Stoke on Trent there a section of road there that makes it sound as if the bearings have gone but it's just tyre noise .possible if you have two different tread patterns might sound as if it's coming from only one wheel Have you jacked the car up at the rear and spun the wheel by hand to see if you can hear any unusual noise If it does need replacing I suggest you soak the bolts in plus gas as they can be a pain to release that's assuming it's the same set up as the mk1 where you replace the hub. On the mk1 you can replace the bearing without replacing the hub.On the mk2 however the bearing is part of the hub so must be replaced as a single unit Not sure what size the torx is but on the mondeo it's a T50 or E12 depending upon type of bolts. Quote Link to comment Share on other sites More sharing options...
