Ford Fiesta Mk6 Gearbox Problem
Hi all,
After driving home tonight I realised once the lights turned green I couldn't get my car into 1st tried several times however wouldn't go in managed to pull off in 2nd checked all other gears and they seemed fine.
I pulled over short while later when I tried getting I in 1st again however kept popping out only managed to get it in once out of 10 tries....
Help?!? Don't trust driving this now
Check the cables under the gear lever shroud, the ball joints sometimes pop off.
Seems to be okay this morning however a little stiff pulling it out of 1st gear to put it into second. Goes in gear fine now though? Any ideas?
Sometimes the cables go rusty, have a look and try a squirt of WD40.
Hi there in response to your 1st gear problem, I had this kind of problem on my mk6 Zetec s
It turned out to be the gear linkage on the front of the gearbox. It went worse after a trip through a flood. There is a cover on the front of the box covering the linkage. Try lubricating it there.
Really really weird problem. Seemed to be fine the next morning and has been ever since?
