David_90 Posted December 14, 2014 Share Posted December 14, 2014 Hello, Driving a long, wearing wellies, went to change gear - pushed clutch down, heard a big plastic like SNAP and then the clutch didn't relase from its bottom position. Pulled over immediately and gently pulled the pedal back up. Clutch working absolutely fine however when you press down with a lot of force (when wearing wellies or the Mrs has boots on) the bugger does not return. I must stress this does not happen a lot it's happened twice in three months. Does anyone know if i can buy a end stop sort of thing to stop this from happening? I assume Ive broken the original so now my pedal can be over pushed. Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 14, 2014 Share Posted December 14, 2014 Sounds like the return spring may have broken - not unheard of apparently. See here http://forums.overclockers.co.uk/showthread.php?t=18315513 There's also a clutch pedal assistance spring which helps with the amount of effort needed to push the pedal down, the plastic end cap for this can break. But your problem sounds more like the return spring. Quote Link to comment Share on other sites More sharing options...
David_90 Posted December 15, 2014 Author Share Posted December 15, 2014 Hi Troy, Return spring in place and working - do you know anymore on the cap? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 15, 2014 Share Posted December 15, 2014 Some more detail here http://www.fordownersclub.com/forums/topic/61638-ford-focus-clutch-pedal/ It's very hard to see where this spring/holder fit unless you lie on your back looking directly up at the pedal box. Quote Link to comment Share on other sites More sharing options...
David_90 Posted December 15, 2014 Author Share Posted December 15, 2014 Nice one Troy, your a big help. Looks like I'll leave the pig alone. As I said it doesn't stick down often and the main spring is fine, so god knows! It's not even as if I had something fall into the footwell so I'm stumped. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
troy45 Posted December 15, 2014 Share Posted December 15, 2014 That may be the best course of action if the helper spring cap has broken - I looked at trying to replace mine and it was virtually impossible. Access to the pedal box is awful once the instrument panel has gone in and it was difficult enough even seeing where the spring was let alone trying to remove it and refit with new cap. Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted December 18, 2014 Share Posted December 18, 2014 Those springs are a total pain. Glue a block of wood to the back of the pedal :-) Quote Link to comment Share on other sites More sharing options...
