steve44 Posted December 18, 2014 Share Posted December 18, 2014 Hello, I have a small but annoying problem with my 2010 mk4 mondeo 1.8 tdci Both the front and rear interior lights will not work when opening the doors bulbs are ok because they will work if I put the switch in the permanently on position Any help would be great Quote Link to comment Share on other sites More sharing options...
steve44 Posted January 1, 2015 Author Share Posted January 1, 2015 Managed to check this out a bit more I pulled the interior lights down and they have 3 wires for the bulb circuit 1. brown/green 12v 2. black/white earth 3. white/brown which goes to the body module I checked the white/brown wire at the body module with a meter and it shows 12v when the light switches are put in door mode If I earth the wire the interior lights turn on, so the wiring from the lights to the module must be intact Just to add the footwell lights work as normal when the doors are opened and closed so assuming door switches are working fine Does this sound like a body module fault? Is there any other reason why it won't turn the interior lights on? Is there any reset you can do on the body module? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted January 15, 2015 Share Posted January 15, 2015 It could be as simple as the switch. Try this, take the light unit out, pull the switch out altogether and turn it around 180 degrees and reseat it! I did this on my rear light and it works a treat! (OK so 0 is On and 1 is off lol, but it works!) Quote Link to comment Share on other sites More sharing options...
