Ford Fiesta Zetec 2006 Mk5 - Tail Light Not Working
Hey,
Thanks for taking the time to read this, Here is my problem -
On my Ford Fiesta Zetec the tail light does not work... the brake light does however... this is confusing because the TAIL light and the BRAKE light are both the same bulb....
I have removed the bulb and tried 4 others and the brake works but not the tail...
Any suggestions?
First thing to do is check the fuses. Although it uses a twin element bulb, the wiring to each light will be different. So look for rear tail light fuse, and see if that helps.
