Jay83 Posted December 29, 2014 Share Posted December 29, 2014 Hi I have a 1.8tdci and sometimes I just won't start and I have to bump it because eventually the battery goes flat,onces started it's fine for days them does it again,I have tryed to jump start it it turns over but doesn't start any help would be welcome thanks jay Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MiltyG565 Posted December 29, 2014 Share Posted December 29, 2014 When you turn the key, does it click? Quote Link to comment Share on other sites More sharing options...
Jay83 Posted December 29, 2014 Author Share Posted December 29, 2014 No the engine turns over but will not fire Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MiltyG565 Posted December 29, 2014 Share Posted December 29, 2014 There's a couple of things it could be. Glow plugs, fuelling, fuel pump. Although if you can bump start it, I'm inclined to think it's the glow plugs. Quote Link to comment Share on other sites More sharing options...
Jay83 Posted December 29, 2014 Author Share Posted December 29, 2014 I changed 3 of the glow plugs need to change the last 1 as I ran out of time but it also does it when it's warm after a long run thanks Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MiltyG565 Posted December 29, 2014 Share Posted December 29, 2014 Ok, so that's a bit harder to diagnose. Are there any other problems? Is it using a lot of diesel or oil? Is it low on power when driving along? Does everything sound normal when it's turning over but not starting? Quote Link to comment Share on other sites More sharing options...
Jay83 Posted December 29, 2014 Author Share Posted December 29, 2014 No everything is fine and it runs really nice starts/stop then out of the blue it does it again.i have read about people having trouble with anti shudder vavle and there symptoms sound the same as mine Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
MiltyG565 Posted December 29, 2014 Share Posted December 29, 2014 That could be it. I have no idea what that is, so I can't help. I'd research it a bit more if I were you. Quote Link to comment Share on other sites More sharing options...
Jay83 Posted December 29, 2014 Author Share Posted December 29, 2014 Will do thanks anyway mate Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
