St Is Getting More Power Next Week!!
If the maf housings they have sent you is not the same diameter as the original one then it's for a different car, ZS maybe. For the maf sensor to get a correct reading on airflow it has to be inserted into a housing tube of the specific diameter that the ecu is calibrated to, so if you change the diameter you will need a new custom map that tells the ecu this.
  • Replies 50
  • Views 8.4k
  • Well that's the worst way of selling a power upgrade possible, it needs to compare standard peak to modified peak not at a pont in the rev range to make the gain look the most impressive
