tractorboi711 Posted January 3, 2015 Share Posted January 3, 2015 Hi I've had the airbag warning light on constantly on my dash for a few months. It started after I had a battery collapse, got a new battery installed it and the light came on , first thing someone told me was to change the airbag module as I had tried to jump the car with the old battery in then I tried to use a tractor battery booster to get it to go, the bloke thought I may of fried the module. So I changed the module but the light still came on. Next thing I was told was to check the connectors under front seats but I don't appear to have any, I have taken of the bottom of the seat to check. Is there anything else I can try to do to get rid of this warning light ? Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
mintalkin Posted January 3, 2015 Share Posted January 3, 2015 when you first turn the ignition on does the light flash ? if it does it may be flashing a code number,if it does not you will have to get the codes read to find out what it causing the problem. Quote Link to comment Share on other sites More sharing options...
