AlanMoffat Posted January 4, 2015 Share Posted January 4, 2015 I had to respray my back panel got the paint code and went to Halfords but when I sprayed it its looks like this can anyone help Quote Link to comment Share on other sites More sharing options...
laumk7 Posted January 4, 2015 Share Posted January 4, 2015 Large panels it's best to get professionally done, you'll never get a good finish over a large area with a rattle can Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
AdeMk1 Posted January 4, 2015 Share Posted January 4, 2015 Did you do it outside too in these low temperatures? It is possible to get a decent finish with a can, but ideally needs to be done in the right environment too - ie a heated garage etc. Did you use a clear coat after the colour coat? Quote Link to comment Share on other sites More sharing options...
AlanMoffat Posted January 5, 2015 Author Share Posted January 5, 2015 Was outside but was not that cold would try again but don't have a garage and yes clear cost was put on to Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted January 5, 2015 Share Posted January 5, 2015 I'm a professional detailer and I looks like u need to do a full wet sand and machine polish like a body shop will do. As when u paint panels it is nearly always the case as u will get orange peel effect and dry back. A full wet sand and polish is always the final stage in any paint process to achieve the final finish u want. 1 Quote Link to comment Share on other sites More sharing options...
AlanMoffat Posted January 5, 2015 Author Share Posted January 5, 2015 So is that all I need to do or dose it need resprayed Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted January 5, 2015 Share Posted January 5, 2015 Id say try that first and see what u think really. If you went to a body shop for painting it would definitely be the last thing they will do. It's hard to say from photos as they don't always show it up properly. It's certainly the cheaper option than a respay. Quote Link to comment Share on other sites More sharing options...
StevenST13 Posted January 5, 2015 Share Posted January 5, 2015 Looking at the photos again I would say that that will probably sort out the paint. Quote Link to comment Share on other sites More sharing options...
AlanMoffat Posted January 5, 2015 Author Share Posted January 5, 2015 Thanks mate all try that Quote Link to comment Share on other sites More sharing options...
